I need some advice on a suitable room thermostat. I have a typical Honeywell ‘S plan’. The room thermostat is fed by three wires (twin and earth) from the potterton controller. When the controller calls for heat the voltage across these wires is 240V. I replaced the ancient brown thermostat that was there with a Danfoss RT1. This is causing me major problems. When I wire it up as instructed nothing happens. I get no ‘click’ and the boiler doesn’t fire. I checked the rest of the system by getting the frost thermostat to kick in. I also bridged the bare wires behind the thermostat and the boiler does fire that way. Does anyone know if these thermostats are suitable for 2 wire applications? If not can anyone recommend one?
