Hi Guys.
I've been a long time lurker, learnt loads of stuff, but now have a bit a weird question for you guys.
I bought a flat a few months back with a view to renovating it, it's not in a bad state, but it looks like the old owner was a bit of a dabbler who was rubbish at DIY. Needless to say I've been slowly fixing little bits, but am now moving on to the slightly bigger jobs.
I'm looking to completely rewire the place and then get everything tested and signed off by an electrician friend of mine.
It's a relatively small 2bed flat, with 2 x 63A feeds coming from the meter two floors down, I've not had much of a chance to explore downstairs but as far as I can tell there are 2 63A fuses down there off of which run the feeds to 2 separate fuses boxes in the flat, one in the kitchen and one in the hallway, doing separate parts of the house.
I can't really change the two cables that run up to my flat, as they appear to run through someone elses walls.
Is there a way I would be able to consolidate these two feeds into a single consumer unit? I figured since I want to swap out the fusewire for RCD protected units I might as well tidy everything up in the process.
Is this do-able ? What would be the best way of doing this ?
Cheers
Cheers
