22 mm pipe into 3/4 T piece
30 Aug 2006
Kent
I am having to replace a hot water feed from the tank to a new wash hand basin in the bathroom. i am using a 22x22x15 Tee on the new pipe, but am having to try and connect the 22mm pipe into an existing 3/4 inch tee to be able to feed the kitchen hot tap & the vent pipe.
Is there a connector that i can use to reduce the pipe to tee connection.
You will need to buy convertors either in soldered type or compression.
You can use 22mm compression with 3/4" olives.
I've had a plumber round who has suggested that - what he will do is cut the 3/4 pipe either side of the TEE and add a couple of reducers 22 x 3/4 and a 22x22 Tee. :D
