22 mm to 38 mm connection
22 Apr 2006
Surrey
Guys please help,
My 30CDI greenstar (Worcester) boiler has a 22mm condensate pipe, need to connect this to a bath room waste pipe which is 38mm (1.5 Inch).
How do I go about this please :(
22-38mm adaptor?
I "often" take things to my local plumbers mercahnt and say i want to connect this to this, and hey presto they ususaly find the thing i need
Samal said:
Guys please help,
The installer should know what is available, and in any case the easiest way to run the condensate into the waste pipe is to use an normal 11/2" tee and a washing machine stand pipe. The 22mm Plastic then hooks over the top with fittings and you have the required air gap.
