Anybody know where one can buy 22mm burst pipe compression fittings? Had two from a sale at Homebase but used them on a "difficult to sprag" section of pipe. Can source 15mm but not 22...
The fitting you mentioned is £20.94! (http://www.tbsmerchants.co.uk/cgi-bin/build/product/PGCO_Conex_Compression_Fittings.html)
Today, from a local merchants, I grabbed one of those little things that you can stick in a drill that sand things down (like a little rough stone ball on a stainless shank that goes in a drill).
Used that to sand away the thin ridge in a brass 22 compression - took a few minutes. Voila - have a slip compression coupler. Two of these with a piece of 22 just make life easier when a pipe will not "sprag" - as in when trying to insert a 22 T into a solid run of 22 (cut out length of pipe and replace with similar length with the T in and use the slip couplers.
Yes I know one can use end feed slip couplers but sometimes damp pipes necessitate compression or pushfit.
