I would have thought it obvious even to an amateur, that 22mm coated is not 22mm od with the coating.
It will not fit in the guide unless coating removed.
you can do it,
the pipe can be difficult to get out the bending machine after and the coating will be rippled at the back of the bend and thinner on the outside.
