If fitting an outside tap, or drilling pipework through internal walls for central heating/general pipe runs, is it necessary to have a 22mm copper sleeve, or can you simply go straight through with a 15mm pipe?
If you must have a 22mm sleeve, what is the reasoning behind it?
