I am replacing rads after an air source heat pump conversion earlier this year.
With the drop in system temp I am using bigger rads and fitting a 1600 x 600 stelrad K3 in the dining room. The 22mm feed from above will tee to feed a pair of rads in two rooms on the 1st floor and this one downstairs. The existing drop is 15mm and is only feeding this one rad. Is there any benefit to re-running it in 22mm, will this increase the flow at all, to take the 22mm pipe closer to the load? The radiator tails will be 15mm anyway via a decent trv, Drayton or Honeywell.
Cheers.
Cheers.
