Have a small leak on a mains fed pipe to the bath (22mm) - but the pipe is old (over 40 years I would say) so would be imperial size.
It is an elbow fitting that is where the drip is from. A solder-end feed type.
Is this usual or rare? The cold pipe is fed from the mains.
Would I be able to repipe using normal 22mm fititng(s) or would I need a reducer. Any tips on how to fix the leak easily and quickly?
