I have one of these:
One of these
And I've tried both an Ultex (which I thought was a good brand but might have turned out to be an ITS special) and Norton
which might also have turned out to be a toolstation special
I have not particular beef against either company, but something about this set up meant it took literally HOURS to split a rusting 40mm box section length ways twice (2.4m x2)
It seems that the discs "clog" up after a minutes use in a way I've never had happen to me with 115mm grinder and thin cutting discs, even the cheapest brand. The speed of the angle grinder is fixed at 6600rpm so there's nothing I can do about that.
What with the grinder being fixed to the stand it's always cutting at the same angle as it were, no back and forth rubbing action (giggidy) that can be done with a handheld.
Are these discs ****e? Is the speed wrong? I find that the heavily rusted surface seems to clog up the discs quicker but once I'm through to clean metal progress is still dead slow, it's dragging and can hear the 2kW motor slowing. I turn the disc over and cut with it briefly (NAUGHTY!!!) and turn it back again and it seems to muck out all the crap and work well again for a minute or so.
Which brand should I go for, or is it just the fixed angle of attack that is causing this problem?
Nozzle
One of these
Nozzle
