2391
21 Mar 2007
Durham
Hi, just booked onto 2391 at college, however im under no illusions that i will pass its just i managed to get the course free and thought if nothing else itll be good experience and insight to the course....
so far i have:
c&g 2330 level2 (start final year sept)
17th edition
pat test
ive built a test board to practice on, (using megger 1552) and wanted some advise on a good study guide/ book to get me started before college course - just so i dont look like total numpty when i get there ;
I did my 2391 many years ago and I would say I was lucky to have a good teacher who directed us right and it is very easy to fill your head full of knowledge not required for the exam or test. I would ask you teacher for advice.
It is the silly things so do fill in your test results etc and get sample checked for many years I put MCB or Fuse as Type in Overcurrent device instead of C or BS 88 etc. And knowing Method of fault protection was EEBADS but changed with 17th Edition not going to say what should be entered now in case I get it wrong. I remember I failed sockets as having bad connection as the recorded was a far bit higher than the consumer unit only one meter away then found resistors had been used to simulate a longer run.
But unlike the C&G 2382 your not allowed the red book and the example I got was farm building and I knew there were special regulations but could not remember exactly what they were so did some guessing must of got it right as I passed.
Eric
Ezekiel,
I can tell you how i revised and passed the 2391 i dug out my copy of GN3 and read it back to front , then condensed all the information down to 3 pages of A4.
The one thing that really must be spot on with the 2391 is terminology for example EIC should be written as Electrical Installation Certificate the first time you refer to it.
Drawings should be labelled clearly and neat.
Section A is a quick fire 20 questions pretty much one sentence answers
Section B they are looking for a more detailed answer i found if you look at the total marks available for the question you can tell wether or not they want you to go into more detail with you answer.
I was reletively lucky as i met a guy whilst on holiday who used to mark the 2391 papers the above information is based on what he told me.
Hope this helps
Carpman
Take a look at the chief examiners reports. They will give you an insight into why people fail and the pass rate.
http://www.city-and-guilds.com/cps/rde/xchg/SID-0AC0478C-B054AD3C/cgonline/hs.xsl/17381.html
As far as books are concerned you will need GN3 as the exam is based on this
http://www.theiet.org/publishing/books/wir-reg/inspection-testing-5th-edition.cfm
In my opinion the Amicus books are great as they are well illustrated, cheap, and pocket sized. The red one is very useful as it has all the cable rating charts as well as others taken from the onsite guide ie trunking factors, bend radius, clip spacing, Zs values etc etc all in a pocket book ;)
http://www.technicaltrainingsolutions.co.uk/publications.shtml
The test rig is a good idea but don't practise bad habits. Make sure you check equipment and leads for damage, prove dead in the correct way, and carry out tests in the correct sequence.
Practice will help as you will get faster at testing, as the 2391 PIR doesn't allow much time to fanny around :D
regards
I also found going through a few past papers helped get my head around the terminology the exam uses, some of it is clear as mud!!
I found the NICEIC guide to IT&C a good read, albeit the forms they use are slightly different.
just ordered copy of guidance notes and trying to get hold of past exam papers (proving hard to find: )
There were some on the old sparkyheaven site before it got shut down, I'll have a look as I may still have them on disk
thanks just got hold of this lot, think it may cover my needs :)
although i have noticed some terms changed since 17th
2391 week-by-week COURSE / WEEK 1 & 2 Inspection & Testing (Basic).
2391 week-by-week COURSE / WEEK 10 2391 Revision Questions 1
2391 week-by-week COURSE / WEEK 10 2391 Revision Questions 2
2391 week-by-week COURSE / WEEK 11 + TESTING AND INSPECTION
2391 week-by-week COURSE / WEEK 3 Instruments & Testing
2391 week-by-week COURSE / WEEK 4 - 6 Inspection & Testing (Advanced).
2391 week-by-week COURSE / WEEK 7 Earthing Arrangments.
2391 week-by-week COURSE / WEEK 8 Earthing Calculations.
2391 week-by-week COURSE / WEEK 9 Certification & Inspection Overview
Software for IEE Certificates / Setup
Software for IEE Certificates / Setup.
Software for IEE Certificates / data1.cab 431 KB
Software for IEE Certificates / data1.hdr 9.9 KB
Software for IEE Certificates / data2.cab 512 Bytes
Software for IEE Certificates / error1.txt 443 Bytes
Software for IEE Certificates / error2.txt 798 Bytes
Software for IEE Certificates / forms / 2001 F1, Short - inc F3 & F4.pdf 634.4 KB
Software for IEE Certificates / forms / 2001 F2, Guidance for Recipients.pdf 56.6 KB
Software for IEE Certificates / forms / 2001 F2, Standard - inc F3 & F4.pdf 754.1 KB
Software for IEE Certificates / forms / 2001 F3, Schedule of Inspections.pdf 169 KB
Software for IEE Certificates / forms / 2001 F4, Schedule of Test Results.pdf 279.6 KB
Software for IEE Certificates / forms / 2001 F5, Minor works.pdf 184.5 KB
Software for IEE Certificates / forms / 2001 F6, Guidance for Recipients.pdf 52 KB
Software for IEE Certificates / forms / 2001 F6, Periodic - inc F3 & F4.pdf 732.8 KB
Software for IEE Certificates / forms / F1, Short - inc F3 & F4.pdf 557.8 KB
Software for IEE Certificates / forms / F2, Guidance for Recipients.pdf 42.9 KB
Software for IEE Certificates / forms / F2, Standard - inc F3 & F4.pdf 596.9 KB
Software for IEE Certificates / forms / F3, Inspection Schedule.pdf 151.2 KB
Software for IEE Certificates / forms / F4, Test Result Schedule.pdf 271.8 KB
Software for IEE Certificates / forms / F5, Minor works.pdf 159 KB
Software for IEE Certificates / forms / F6, Guidance for Recipients.pdf 43.3 KB
Software for IEE Certificates / forms / F6, Periodic - inc F3 & F4.pdf 643.1 KB
Software for IEE Certificates / forms / Forms.pdf 367.8 KB
Software for IEE Certificates / forms / logos / BLANK.pdf 1.8 KB
Software for IEE Certificates / forms / logos / CIBSE.pdf 18 KB
Software for IEE Certificates / forms / logos / ECA b&w.pdf 17.6 KB
Software for IEE Certificates / forms / logos / ECA.pdf 18.5 KB
Software for IEE Certificates / forms / logos / IEE.pdf 23.4 KB
Software for IEE Certificates / forms / logos / IEEnew.pdf 4.7 KB
Software for IEE Certificates / forms / logos / IIE.pdf 10.3 KB
Software for IEE Certificates / forms / logos / SELECT.pdf 8.5 KB
Software for IEE Certificates / forms / web_up4.pdf 90.6 KB
Software for IEE Certificates / forms / web_up6.pdf 111.2 KB
Software for IEE Certificates / formsiee.ico 2.2 KB
Software for IEE Certificates / ikernel.ex_ 331.6 KB
Software for IEE Certificates / layout.bin 417 Bytes
Software for IEE Certificates / plug_ins / ieeforms.api 174 KB
Some past papers and revsion help / 2391 Revision Questions 1.ppt 78 KB
Some past papers and revsion help / 2391 Revision Questions 2 1003.ppt 77 KB
Some past papers and revsion help / 2391-june2000 answer.pdf 2.1 MB
Some past papers and revsion help / 2391-june2000 question.pdf 1.5 MB
Some past papers and revsion help / 2391exam paper 2.pdf 995.1 KB
Some past papers and revsion help / 2391exam paper 3.pdf 846.1 KB
Some past papers and revsion help / 2391exam paper 4.pdf 1.3 MB
Some past papers and revsion help / 5june2001.doc 26 KB
Some past papers and revsion help / 5march2004.pdf 69 KB
Some past papers and revsion help / ASSESSMENT All.doc 71.5 KB
Some past papers and revsion help / Answer to Week one1.doc 137 KB
Some past papers and revsion help / C&G 2391 Exam Paper 1 JUne 2003.pdf 1.6 MB
Some past papers and revsion help / C&G 2391 Exam Paper 2.pdf 995.1 KB
Some past papers and revsion help / C&G 2391 Exam Paper 3.pdf 846.1 KB
Some past papers and revsion help / C&G 2391 Exam Paper 4.pdf 1.3 MB
Some past papers and revsion help / IP Code.doc 42.5 KB
Some past papers and revsion help / Inspection and testing.doc 38.5 KB
Some past papers and revsion help / Long questions June 2003.doc 32.5 KB
Some past papers and revsion help / Sample questions and answers 2391 theory exam1.doc 38 KB
Some past papers and revsion help / Short Answers June 2003.doc 44 KB
Some past papers and revsion help / Shower scenario.doc 29.5 KB
Some past papers and revsion help / TESTING MANUAL with answers 71.5(1).doc 74.5 KB
Some past papers and revsion help / Testing manual without answers 71.51.doc 71.5 KB
Some past papers and revsion help / WEEK ONEand two REVISION(1).doc 36 KB
Some past papers and revsion help / WEEK ONEand two REVISION.doc 36 KB
Some past papers and revsion help / WEEK three 2391.doc 39 KB
Some past papers and revsion help / Workbook1(1).doc 74 KB
Some past papers and revsion help / Workbook2.doc 74 KB
Some past papers and revsion help / city and guilds 2391 exam paper.pdf 1.6 MB
Some past papers and revsion help / minor work certificate.doc 71 KB
Some past papers and revsion help / pat workbook.rtf 182.9 KB
Some past papers and revsion help / question for Week one).doc 37 KB
Torrent_downloaded_from_Demonoid.com.txt 47 Bytes
Video For Testing with 2391 / Read Me.nfo 6.8 KB
Video For Testing with 2391 / Testing to BS7671.mpg 393.7 MB
electracourse info / 2391 Revision Questions 1.pdf 99.5 KB
electracourse info / 2391 Revision Questions 2.pdf 90.1 KB
electracourse info / 2391- Certification & Inspection Overview.pdf 1 MB
electracourse info / 2391- Earthing Arrangements.pdf 479.9 KB
electracourse info / 2391- Earthing Calculations.pdf 305.6 KB
electracourse info / 2391- Inspection & Testing (Advanced).pdf 6.1 MB
electracourse info / 2391- Inspection & Testing (Basic).pdf 6.9 MB
electracourse info / 2391- Instruments &Testing.pdf 1.1 MB
electracourse info / 2391- Manual - Inspection and Testing of Electrical Installations.pdf 7.6 MB
electracourse info / Exam Paper 1 - 2391.pdf 185.9 KB
electracourse info / Exam Paper 2 - 2391.pdf 1.1 MB
electracourse info / Exam Paper 3 - 2391.pdf 930.6 KB
electracourse info / Exam Paper 4 - 2391.pdf 1.4 MB
electracourse info / IMPORTANT UPDATE - Cable Colours Leaflet.pdf 277.7 KB
Hey Ezekiel....Good luck with the 2391...I aint gonna lie to you and tell you its easy...Many have failed this examination but dont be dismayed
The practical ...I think everyone passes that. But the theory can be hard work
My advice is to somehow get hold of some pass papers which will give you a feel of what you can expect
Also I dont know if you have all the meters needed (3) but you can pick all 3 up very cheap on EBAY as many sparkies are selling off as they buy the "all in one "type
Decyphering and fully understanding the questions can be a bit time cnsuming as it aint always easy to know straightaway what the b astards are asking for
Anyways good luck mate...You will fly it I am sure...its us old f arts who struggle
Cheers
thanks spark think i have obtained a lot of them, but could use the newer tset papers (2007) if poss
jujubean picked up a megger 1552 for £350 never been used so think i caught a bargain - does this cover all tests thought it did with possibly exception of earth electrode resistance?
Yep, the 1552 does all the installation tests bar the 3 or 4 wire electrode test which isn't really a big problem unless you are installing the likes of generators or the means of earthing to a supply transformer.
You should also have a set of GS38 approved voltage indicators which are better for testing dead and pol live.
You have email
