Hi there,
We have recently had a nest put in to replace the our old room stat and timer setup.
The old setup was a Honeywell dial stat. With a dial timer on the boiler. The only cable coming out of the boiler apart from power was T&E connected to the 24V switching section (not the 240V section which the nest is connected to) This cable is 100% not live having been disconnected.
Rather stupidly i assumed the cable would lead directly through the walls and terminate at the Honeywell dial stat thus i could use it as a hard connection for the heatlinks T1 and T2 connections without having to power it via usb. But i've found that at the stat end it is connected via T&E but the cable is live (tested) and the stat is a T6360B which is a 240V.
The cable run can't be seen as it snakes through the house. I'm assuming at some point the 24v signal from the boiler is being converted to 240V - is this something that is possible? And if so shouldn't the converter be somewhere inspectable?
I'm happy to run the nest via USB but would rather have got it hard wired in.
