I'm wiring in 5 soffit lamps that I'll want off two circuits, in a new roof that has not been felted yet.
Ideally each lamp will be connected via a single 1A solid T&E cable, but should I route these 5 individual wires into the loft space for junction box connection - or should I put the junction boxes into the soffits to save cable?
Also how should I route the wires - just use nail/cable clips every 0.5m to route them up the centre of each rafter?
The switches would ideally end up on the wall and switch from the lighting circuit, so either way I'll need to get back to a wire to be routed down the wall in a channel.
Thanks in advance!
Thanks in advance!
