Why would you wish to do this?Does changing from a 240 v fitting to 12v downlighters in a bathroom come under part p
Yes.Does changing from a 240 v fitting to 12v downlighters in a bathroom come under part p
Yes.and does swapping an existing shower unit for another also come under part p
There is no "therefore". The works you identify all "come under Part P" because Part P (in fact all of the Building Regulations) applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter which operate at low or extra-low voltage and are—and therefrore is notiviable work ???
Yes, and Range Rovers have better fuel economy than Landcruiser Amazons so you'll travel further on a gallon of petrol.They do produce a better light, and more lumens per watt, so you get more light for the same amount of electricity though
ner ner!Yes, and Range Rovers have better fuel economy than Landcruiser Amazons so you'll travel further on a gallon of petrol.They do produce a better light, and more lumens per watt, so you get more light for the same amount of electricity though
No, its not like for like.So if i am changing like for like in a bathroom its part p then
Which part of The Building Regulations says it has to be?No, its not like for like.
Which part of The Building Regulations says they have to be?The lights must be the same rating (voltage and wattage).
Which part of The Building Regulations says it has to be?The shower must be the same rating.
Care to point to the part of The Building Regulations which states that?PART P of the building regs states that LIKE FOR LIKE replacements are NOT NOTIFIABLE.
