Hi I have a partial electrical background and I'm sure I knew this but I just cant work it out now. I'm retired now maybe I'm forgetting this stuff after not using it much.
Anyway, I have a power supply for some LED tape, they all came together and I have one of those 2A round pin sockets to plug it into. I felt like checking everything was correct, i.e that it does not draw more than 2A.
The power supply says Input 100V-240V 50/60htz 1.6A so ok for 2A socket and the ouput says 12V 6A but how do you get from 1.6A to 6A, i.e. how do you calculate this?
I know the equations V=IR and W=IV so for example 240/1.6A (V/I=W) = 150watts but 12/6 =2watts so is there a calculations to work out what the Amps are on the other side if you know one side, i.e if you knew it was 1.6A on the 240 side could you calculate what Amps it would be on the 12V side or is it all down to the number of windings on the power supply/transformer?
I remember someone used to say to me in the past that with the 12V MR16 lamps that if the lamp was 20 watts it would draw 20watts more or less on the 240 side as well, is that correct?
