I previously posted about insulating my single skin detached garage with 50mm EPS board laid over battons, however I have since decided to go with a 2 x 3 timber frame to give the walls the strength I need.
This will leave me with a 75mm gap to play with. I don't trust that my walls will remain free of moisture all year round, so am keen to have a 25mm air gap between brick and insulation. I would also be covering the EPS with thermal bubble foil insulation which would also act as a vapor barrier but requires a 25mm air gap for the insulation to be effective, leaving me with a 25mm gap for my insulation boards.
Should 25mm EPS, coupled with the bubble foil insulation, be effective enough in retaining heat?
I expect the obvious alternate would be to use PIR boards, but I'm working with a low budget so unfortunately this wouldn't be an option for me.
