I have a 25mm blue pipe into the house in the front room under the floor. It comes through the foundations, then it changes via a 90° pushfit connector to 15mm plastic and goes under the floor to the stop tap (also pushfit) under the stairs.
Is this correct? I thought the stop tap should be straight on the end of the blue pipe?
The blue pipe is lagged and inside a black ribbed pipe.
The 15mm plastic pipe isn't lagged. Should it be? Its under the floor boards which is vented to outside.
The distance from the stop tap to the blue pipe is about 5 metres.
Im worried that if the pushfit joins fail under the floor, i'm not going to know about it for ages, and i cant use the outside stop tab in the street because i dont have a key to lift the iron lid.
