Does anyone know if there is a connector for 25mm mdpe to join 28mm copper? or a stop cock that goes from one to the other?
is the current reducer broken?
Common misconception, size of pipe does not alter pressure anywhere, just limits flow.
25mm plastic will be about 22 inside so 28 mm copper inside will be point less. If it is still on the drawing board, get the mdpe changed to 32 and have 28 mm after that with everything else branching of from there. Don’t make the mistake of reducing the 28, keep it all the way to the end
Thanks, I think thats the way to go either that or run the 25mm mdpe all the way up to the linen cupboard and put the stop valve just before the inlet control set then reduce down to 22, not sure if thats allowed though..
