25mm MDPE to copper
6 Jul 2011
Yorkshire
Hello hoping for a bit of help.
I have run 25mm MDPE pipe from the house under the garden and into garage. Have done this so I can have an outside tap attached to the garage wall and put a sink in the garage aswell.
Just wondered what is the best way to connect the MDPE to 15mm copper? I was going to use a JG push fit reducer and then fit an isolation valve. But have just seen there is a 25 to 15mm stop cock. Could I use this and would it eliminate the need for a isolation valve?
Thanks Chris
I'd go for the stop cock option. Probably cheaper, and the stop cock will be more reliable than an iso.
