25mm mdpe X 3/4" female connectors
6 Feb 2010
Blackpool
Hi, do they do 25mm mdpe x 3/4 female connectors. With the 3/4 female part being made of metal not plastic. As plastic can be cross threaded quite easy when connecting to a metal thread.
I am pretty certain they don't make these fittings, at least off the shelf anyway. I have only seen plastic fittings with metal band around the BSP end to add support, nothing to do with making it fool proof to cross thread!
All I can say is, go careful when winding in your threaded pipe, leave a few threads showing after any joint sealing method applied.
Lloyd
Thanks if I can't get hold of a metal one has any one got anymore tips to avoid cross threading can see it being easy done if put a lot of ptfe on the male thread.
Would I be dreaming if I thought I've seen a black iron adaptor?
No. George Fischer (GF) Primofit, available in black or galv, for gas or water.
