Hi
I've just taken a glazed panel or of the bottom of a door, with a view to replacing it with a solid panel so that I can install a cat flap.
I measured the unit as 26mm thick?
I'm struggling to find any mention of 26mm units. Just 24mm and 28mm.
Is this right?
Do I just buy the 24mm and get some thicker seals?
Or since the wedge seals are already 5mm, would I be better with 28mm panel and 3mm wedge seals?
Thank you
Is this right?
Thank you
