Hi all - first post here though I have visited numerous times in the past prior to registering today.
I have a problem with my 10-year-old Worcester 28CDi boiler - not the first problem but the first on which I need to ask particular questions.
I am well aware that any gas work is a big no-no so will refrain from asking questions in that area, however at the moment I am looking at a PCB replacement which should, I hope, be no problem, though I do note that the FAQ says that a PCB may qualify as "gas work"?
The present issue is that when either CH or HW demand is applied, the pump starts but the fan does not, and after 10-15 seconds the DHW indicator flashes rapidly.
Boiler was working fine until last week, and I have performed the following checks as per the service manual (Fail Point J) and other advice:
- Does fault occur in both CH and HW modes? Yes
- Does fan run before fault light? No
- Are APS terminals bridged when off? No
- Are APS terminals bridged when HW is requested? No
- Are APS terminals bridged when red tube is gently blown into? Yes
- Do APS wires have continuity? Yes
- Are APS tubes in good condition? Yes
- Is flue free of obstructions? Yes
- Is there 230VAC across L+N fan terminals when HW is requested? No
This appears to indicate a PCB fault, but does not seem to exclude something having occurred at the fan that has damaged the PCB in some way.
I am aware I can get a WB fixed-price repair for £250, or a BG one for £79/£189/£409 dependent on time taken to fix, but do not currently want to pay that much when I can pick up a new PCB for <~£100 on eBay, a working used one for <~£50, and am quite happy (indeed, enthusiastic) to fit it myself, though I do not wish to do so if unsafe/illegal.
I am fairly familiar with the interior of the boiler as I have done several other pieces of work on it (replaced DV diaphragm, which involves removing W-W HE and various other bits, replaced most fibre washers, fixed loose/exposed(!) room stat wiring left by previous occupant, replaced manual timer with digital one, drained, cleaned and refilled system), but thought I should check I am not missing anything as the PCB is more expensive that any other component I have replaced and obviously I cannot break the gas seal to check the fan directly, nor do I want to get into replacing the PCB if particular checks need to be done afterward for which I am not qualified.
Thanks for any assistance/advice - aware this may consist of "leave it alone"!
