2D lamp ballast change
21 Sep 2016
I have an Ansell light fitting that no longer works. It has a 2D 4 pin fluorescent lamp in it and an
Ohmtronic electronic ballast. Could I change the ballast, assuming that this is what is faulty?
Or could I change the 2D lamp to an LED plate type sort?
You can change either. Are you sure its the ballast, and not the lamp?
personally i would change to LED.
I like LEDs. I have three of these Ansell fittings in my kitchen and, if changing to LED is easy and fairly cheap, I'd change the other two as well. How do I go about it?
Taylortwocities,
Having digested your advice, I have decided to change to LEDs altogether. I've installed a Robus Ohio12w integral Led bulkhead as a test and am very pleased with it. I'll change two more next week.
Thanks very much for your replies.
i converted the 2D's in my own house to led
rip out all the insides and fit a lampholder and led bulb
you can even fit a flush pir into the cover with silicone
mikehammer69
Good idea. I'll play with that when I get the time.
Thanks.
Taylortwocities,
This is a much better idea. The LED retrofits are not good. Enclosing them in a plastic case with no airflow just results in lower light output and reduced life
aptsys,
I can see that and will replace units with new integral LED lights. Glad you posted! Thanks
