I have a standard consumer unit which is full and would like to expand it to accommodate some outside lighting and power. Ideally I would like a second consumer unit mounted a distance away from the primary one. I’m not an electrician but want to plan and do most of the leg work. While Ill get an electrician to connect up the bits I can’t, I have a few questions if anyone could help me out?
1) Ideally I want this unit to be a totally seperate unit. e.g. come from the mains electrics and not piggyback off the first unit.
2) If 1) is possible how far can it be away from the main supply?
3) are there any other considerations with 1)?
4) Can the second consumer unit be placed outside in an IP65 rated enclosure?
