When I moved into my house, it had 2 consumer units, each with its own isolator. In other words, in order to isolate all of the electrics, you had to operate 2 switches. I pointed this out to our electricity supplier, and they have fitted an additional 2P 100A isolator upstream of the CU's. Apart from the slightly loose fitting (it moves a bit relative to the wall, although the screws seem firm), they have mounted it sideways, so that the switch has to be moved right and left to operate. I can see why they have done this, as the space where it is mounted is a bit restrictive. My question is (before I bring them back to tighten the fixing) whether or not mounting the switch sideways is acceptable. Is there anything in the regulations about the orientation of isolator switches?
