Advice please.
I’ve knocked a kitchen and dining room wall down to create a good space.
At each end of th new room I have fitted new 3 gang switches (2way)
At both ends I have used 2 switches to control ceiling lights in 2 areas.
The third switch at each end are used as 1 ways. 1 controlling under cupboard lighting and the other as an isolator for an outside PIR light. All works well.
Now a decision from another person means I have to put dimmers in the 2 way circuits.
I can leave one set of switches as they are, but I’m not sure if I can get switch combination that will give me 2 dimmers and an on/off switch in one module?
I think I can use a grid type set up with correct modules, but I’m guessing I’ll need to use a bigger back box?
If I’m quick I can sort it out before plasterer arrives
Can someone with greater knowledge on kit advise please?
Cheers for reading
Cheers for reading
