3/4" BSP thread to 15mm pipe
3 Jul 2007
Manchester
What's the best way to get from a 3/4" BSP tap tail (~26mm OD) to a 15mm copper pipe?
EDIT - I've found some adaptors and also flexible pipes so a couple of options.
End feed fittings are cheaper than compression :idea:
I opted for 500mm long flexible hoses with a 3/4" BSP threaded fitting on one side and a 15mm compression fitting on the other side. Cost was £5.86ea from B&Q.
Thanks everyone.
