I needed to make a mains water connection to an MDPE pipe using an adapter with a 3/4" female plastic socket.
The standard brass 22mm to 3/4" male only has a short thread about 12 mm which is not long enough to make a good safe connection to the plastic thread.
Are other brass adapters available with a longer thread or any other suggestions?
Will a 22 x 22 compression coupler fit?
Tony
Tony
