I needed to put in a 15mm branch from 3/4" pipe, and conventional wisdom is that a 22mm fitting with a 3/4" olive would provide a satisfactory seal.
Having laid out all the requisite pieces (22/22/15 tee from B&Q; 3/4" olives also from B&Q, tools etc), I noted that the olives from the tee and the 3/4" substitutes had a different profile; the 22mm ones with the fitting had an outer oval profile, the 3/4 had a flat-topped profile.
Double checked that the 3/4 olives were a snugger fit on the pipe than the 22mm, and assembled and tightened. Turned the water on, and got weeping from both 22mm ends, but watertight on the 15mm branch. Tightened up a bit more, with no more success. Tightened as much as I dared (holding the fitting body steady), using a 12in wrench, and on close inspection there was still a slight weep, apparently from the inside of the olive (the edge of which was visible through the fitting nut).
Tried some PTFE tape over the fitting thread and olive, with same result.
Decided to try fresh fitting and olives, opened a second pack, taking scrupulous care (as I did the first time) to keep them clean, and not get any muck on the surfaces. Took out a little more pipe, and in went another 22/22/15 fitting (in case the first one was faulty), a short section of 22mm pipe, and a 22mm straight coupler. 3/4 olives on the outer joints, 22mm olives on the inside ones between the 22/22/15 and the straight coupler. Result? Slight weep from the 3/4 joints, sound joints with no problems on the 22mm.
Possible conclusions;
The flat-profile 3/4 olives aren't compatible with the fitting, which originally had rounded profile 22mm olives?
The pipe isn't quite 3/4 inches?
I just didn't tighten them enough? (but the 22mm were tightened to the same degree and were sound, though.......)
I'd welcome any other suggestions or tales of similar experiences....
Oh, and forgot to mention - I'm going to try setting up a test rig in the workshop as soon as I get a chance, see if I can pin down a definite cause; all suggestions gratefully received in the meantime.....
Regards, Graham
__________________________________
Moderator please note 10a
Regards, Graham
