Have drip coming from a pipe underneath my bath. Don't know why its leaking but discovered it after 2 hours of looking, and finally getting the bath panel off. The bathroom is old and I think the pipe is in imperial, 3/4" and not in metric 22mm. If I cut out the section and clean up and solder a new piece of 22mm pipe with 2 x 22mm straight couplers will this do the trick, or will they not be the right size and leak? do i need special 3/4" pipe and fittings, and if so where are these available from please? Cheers and all the best, Kurt.
