Hello guys.
I need to connect my 15 mm flow and return pipes to my towel rail tha t takes 3/4 inch valve. I understand i can use 3/4 *1/2 inch BSP reducing bush to connect up the 15 mm towel rail valve to the towel rail and CH pipes. Since i have never used a reducing bush, do i need a male to female one so that i can screw the 15 mm towel rail valve straight into the bush ( i do not know if that is possible) or a male to male one and use a small length of 15 mm copper pipe inbetween to connect up the reducing bush to rad valve? Thank you 4 your time and sorry 4 the lengthy explanation.
