3/4" to 15mm isolator valve flexi pipe?
9 Nov 2011
Northumberland
Im busy replacing the bath suite and installed two 15mm isolator valves onto the ends of the existing 15mm cold and hot supply pipes for the bath.
I am struggling to find a 15mm x 3/4 inch braided flexi pipe is this something I might find or have I done something against the grain?
I can see a few 15mm flexi pipes with valves built in etc but was hoping to avoid removing the newly fitted valves.
Cheers
I must be useless at searching for them as I cant see any with 3/4 female end and 15mm female end?
I will have another look must have missed it. If I’m honest I’m new to the whole flexi pipe scene.
Use the 15mm x 3/4", and as swbjackson said use a short section of 15mm pipe between the two fittings.
As you said above your looking for both ends to be female fittings.
That won't be 3/4" x 15mm that would be 3/4" x 1/2".
No worries cheers, forgot about the old 1/2 and 15mm thing. Being of the metric generation it catches me sometimes.
Just wanted to check there wasnt a pipe available before adding a small piece or buying a pipe with a valve built in.
appreciated.
