3.4KW Oven but only a 13a fused spur
27 Mar 2013
Lancashire
Finally found a oven for the new kitchen, its a samsung PKG100 with a 6kw hob and a 3.4kw oven.
This throws a spanner in the works as i've planned to have a click dual appliance plate connected to the ccu (fed on 6mm cable to cu). From the plate i've requested a 13a fused spur for the oven and 6mm cable to the hob.
What can i do with the 3.4kw load? whats normally supplied for this load?
Is the only option wiring it direct onto a 16a radial?
You do not want a 13A fused spur for the oven!
6mm cable to the hob, 6mmm cable to the oven both from the Click dual plate. Job done.
Great that puts my mind at ease again. Next hurdle is plumbing then finding a space for the b&q kitchen delivery :eek:
