Hi, I have to replace an outside PIR light, a simple flood light type. The old one is a bit more sophisticated with lots of wire in the light itself. The incoming cable is 3 cores (Brown, Black and Grey) and earth but the bare earthing cable wasn't used before on the old PIR light.
I cannot figure out how the new one will fit in, it only has a
connector L/N/E but which core goes with which? I looked on the internet one guy suggested the following connection as the 3 cores give an override function but I am unsure how it works.
I wired
Brown to L(ive
Blade to E(arth)
Grey to N(eutral)
It seems to work when I have the switched turned on - override, BUT when I turned it off at the switch and hope the PIR will take over the on/off function, I note electrical shock on the metal body! Clearly what I did was not correct. Question
1) Is the wiring connection correct?
2) How to use the bare earth wire cable onto the switch?
3) Why do I feel the electrical shock on the body?
Please HELP!!
Answer to the forum and e-mail to [email protected]
Thank you in advance
I wired
Brown to L(ive
Blade to E(arth)
Grey to N(eutral)
Please HELP!!
