Hi guys,
Had great advice already from this forum about my trenches, but last few before the concrete gets poured on Friday.
1. The building inspector passed the trenches, but advised I remove all the wet slush before pouring. Did this for a few hrs today, real clay muck that ended up being easier to remove by hand. Is it worth putting in a bit of small (or big) hardcore in the base of the trench to stop any concrete mixing with this mud?
2. After my post about the sides having collapsed last weekend I ended up placing lots of shuttering on one side. The garden side of the trench is fine and stable, but the inside isn't and I back filled some of the clay. Worried this will fall in if I remove the boards just before pouring. In fact the clay has stuck to the sheets. Can I just leave the 12mm mdf on the one side. Surely this can't have any negative impact?
3. Lastly, noseal advised that I measure down from the dpc to mark the top level of the concrete to be poured. I decided 450mm down from the dpc would be fine (6 coarses of brick). I attempted to use a water level to do this today. Nearly impossible by myself, so will buy a laser level tomorrow. 450 from dpc, leaves about 600mm of depth in the trenches for concrete. The trenches were dug 1m. Is this okay. I would have thought that after digging 1m, en the concrete would not be far of this depth. Guess I'm wrong?
Many thanks guys.
Many thanks guys.
