3 gang light switch
21 Mar 2008
Hampshire
Hi guys, does anyone know where I can get a 3 gang light switch that sits kn a double knock out box. Either pre-made or in grid. I know there are plenty of curve edge styles but I need one that has square edges so it matches with the existing accessories (marbo). It used to be a 3-gang dimmer switch.
Many thanks,
Dave
Are you aware of the 'dummy' dimmer modules that can be used to replace dimmer modules with on/off switches? Both rotary and push versions are available - an example of the former can be seen if you click here .
Kind Regards, John
