3 gang switch; one of which is DPDT
3 Jan 2004
I have a double pole double throw switch which is the third switch in a lighting set, and one two-gang switch which is used for two single lights;
I would like to move the two switches to a new location and merge them into a single three gang switch. Switch 1 would be a simple one way light, Switch 2 would be a simple one way light. but switch three would replace the DPDT switch. Does anyone know of a UK supplier of a three gang switch which has one or more of the gangs as as DPDT ? If not, can I use the normal three gang L1/L2/Common to handle the DPDT ?
Thanks in advance, Brian
I don't think you can get 3-gang intermediate switches - there just wouldn't be room for all the terminals.
ChrisRogers is right, you'll need to use a grid system, such as MK or MEM, and fit the modules you need.
