I have the following "problem":
I have 3 layers of glass wool insulation on the loft:
1x15cm (the original - probably 40 years old)
2x10 cm (put in 2007.)
The joists are 15cm tall, so to avoid layering several levels of chipboard/insulation/chipboard, or adding another level of joists, I was thinking of leaving only 15cm of glass wool (probably just removing the original and compressing the new 2x10cm to 15cm) and adding a layer of "styroloft" (insulation on which you can walk on) - but I cannot find any reviews on the quality of this solution. BTW, my joists are approx. 16" apart, but it varies by up to 1" from pair to pair.
If anyone knows whether this would make a bad walking surface, or if it's a terrible insulator - please let me know! Otherwise I am ordering some 8cm (to get the R factor of 6.1) thick boards and getting on with the job!
Cheers,
Labud
Cheers,
Labud
