fired up the ole boiler to find out that 3 of the 7 rads wont get hot. try to bleed and cold water immediately comes out. actually, one gets warm water coming out, but by no means hot. both supply and return pipes are cold to rad(s).
the 2 cold rads are above each other off the same mains ( also cold)
the system pressure is at about 15 psi.
is the system not totally full ??? how can i tell if it is or not ?? is there an air pocket somewhere in the line ??? how do i flush it out ??
lookin for your input. thanks, cooper
