Hi folks,
Hoping you good people could help me out with an idea I've had:
I'm on a 3 Phase Supply (formerly a commercial site turned into small apartment). My terminology is way out but it seems only 1 of these 3 'phases' are metered (@100A). The other 2 'phases' (100A and 80A) are simply security sealed.
The meter extends into a CU which has plenty of blanks. This CU as 3 MCBs rated at 6A (Lights), 32A (Sockets) and 45A (Electric Shower) - they are all RCD protected.
I'm looking to extend the supply to the adjacent (vacant) room which I want as a mini workshop for hobbies & crafts. Money is no object here & I have enough cable lying about. Also, I like it looking all neat & tidy. So here is the plan:
Step 1...Add 1 x 45A RCBO to existing CU
Step 2...Run 5 meters of 10mm 2 Core&E to new 2 Way CU which will have RCD
Step 3...Insert (to new CU) a 32A MCB for sockets and 6A MCB for Lights
Step 4...Begin circuits (3 sockets + 2 lights)
This is perhaps overkill but as mentioned above, I have enough bits lying about. My questions are:
1....whether the above would work fine? and is the way to go
2....are meter tails from CU to CU necessary or would the 10mm twin Core&E suffice? Cable would be surface mounted in trunking with no bends or twists - straight and clean run of 5 meters
3....If I wanted the hobbies room metered (and if I went overboard again), could I 'engage' another phase from the supply and meter it with a separate CU? or would you recommend just Henley Blocking the existing phase and installing a submeter?
4...Do you recommend separate lighting circuits (2 tube lights) or could I simply use the socket circuit for lights too?
Appreciated
Appreciated
