Hi I hope you can advise, I'm looking to buy a used coffee machine, the one I'm looking at is 5.2KW and it's 3 phase, question is: can I conect it to a single phase supply and if not can it be converted? Thanks
...(you might need to be careful about the internal wire size on what was the neutral, since with single-phase it would then have to carry the full-load current).
If it was wired to 3 phase supply then surely it wouldn't have an internal neutral wire? Not for the heating elements at least.
I presume you are assuming that the 3 elements were each connected individually to each phase with their own neutral then and not linked across each other?
If they're 240V elements they would have to be wired phase to neutral (yes, in theory they could be wired in wye configuration without a neutral being connected, but practical constraints make that rather unlikely).
If the element is wired across two phases then it would have to be a 415V element. I'm not sure if that's what you meant by "linked across each other" though.
So how would the elements be physically connected?
If star, would one end of each element be connected to a common point with the other end of each element connected to L1 / L2 & L3? And if this is the case I presume you could potentially connect a neutral to the common point?
If delta, one end of each element connected to one end of the next, essentially putting all 3 elements in series then one phase to one terminal of each element?
Yes, that is what I meant. Just trying to visualise how they would be physically connected...as my questions above.
In practice, there is bound to be a small neutral current since it's impossible to make all three elements exactly the same.
