My 3 port valve (Sunvic valve and 2701 actuator) is not working I think i.e. HW always heats when CH is on. I assume it is functionally stuck at mid-position.
I removed the actuator and it still moves to 3 distinct positions when programmer asks for CH or HW or both.
The spindle of the valve turns smoothly and does not seem corroded etc. It can be twisted 360degrees - not sure if that's normal!
I actually foolishly bought an actuator (SD 2701) from heatingcontrolsonline.com but reluctant to open it as I may need the combined actuator/valve (SD 2211) which actually costs less than actuator alone. D'oh.
I tried shifting the valve around, but difficult to tell where the hot water goes as pipes all stay quite hot.
To complicate, I have a frost-stat which keeps turning on the system as it has been so cold. Can this send the valve to mid-position. I'm sure the problem predates the cold snap anyway.
How can I tell which part is not working? Thanks for any help out there...
