OK... Can any plumbers who've installed lots of these recommend any reliable makes? The easiest to find seem to be Honeywell, but my current one is a an ACL Drayton and I was hoping to find the same one so I end up with a spare head. However I'm not sure mine is still available.
ACL Drayton are widely available, and cheaper than Honeywell (put possibly not as good - more prone to leak perhaps). The head you have will not necessarily fit a new valve body. You might want to consider a much cheaper Orkli valve from BES.
