Hello
I have a blockage in my cast iron 3" soil pipe. The toilet is blocked up and the bath is also not draining away as the 40mm plastic pipe fits into the cast iron tee section.
I think the easiest thing to do is cut out the cast iron suff and replace in plastic. However i cannot find any 3" pipe, it is all in 110mm.
So do i just cut the cast off at ground level ? This is pretty straight forward, but how do i connect up 110mm plastic to the smaller cast pipe ?
OR is there 3" stuff i can buy so i keep the cast above the Tee (where the waste enters the pipe) and have plastic in the lower section? I hope this is ok to understand.
Any help appreciated.
