3" toilet waste
14 Apr 2006
Hampshire
the toilet vent from 1st floor bathroom turns into 3 inch vent to fit up inside sloped roof , want to put toilet on 2nd floor can i use 3" pipe not 4 to tee into vent. only one toilety basin and shower waste seperate, if not only real solution macerator which dont want to do
cheers jon
you can buy a 3" toliet connecter. if its a cast iron you might have some hassle getting the connector in then you can buy a 3" sleve although there tricky to locate most merchants will be able to order it for you however if you do go for this method i sugest putting one of those things that close when you tighten the screw lmao forgot the name of them.. hehe but basically hose clip. but there are 3' tolet connectors avaliable with a pan connector on.
oh its not a 3inch going in to a 4inch lol sorry yeah what the guy said is right woudlnt even try it would be ok if the down pipe was 4"
