I've replaced a section of pipe which serves as a feed for the shower (hot water), the pipe and couplers were all corroded up from a leak. All went fine apart from when I was fitting the new 3 way coupler which is a 15mm on one side and 22mm straight thru. On the 22mm run side connecting to the old 22mm pipe the olive fitted to the coupler was oddly quiet a loose fit hence it's now proving to be quite hard to stop water leaking. I've tried packing the join with ptfe tape twice and as a last resort I'm now doing to reassemble but this time pack as much tape under the olive as I can.
Any words of wisdom would be great. See attachment.
