Hi, can anyone help me?
I want to control 3 light circuits from 3 positions. I've got 2 3-gang switches, but can't get a 3-gang intermediate switch in the style I've chosen.
I've now bought a 3rd 3-gang switch as I believe that relays can be used and am hoping someone will have a diagram for this - anyone?
Sounds like a hard way of doing it.
If you do it in
MK Grid Plus, you can get
intermediate switch modules. I think the intermediate switches only come in 20A. For the 2-way switches at each end, you will likely want to use
10A switches, assuming that this is a 6A lighting circuit.
As well as white frontplates, there are
a few different colours of metal as well.
Not only that but with wiring up 3 switches on a conventional switch it is damned hard work pushing the wired-up fitting back on to the wall. With MK Grid Plus, you can wire up each switch separately and just clip it into the frame, then put the front plate on when you're finished.
The MK Grid Plus system can look a little daunting if you haven't used it before, but in fact it is really easy to use. (It will almost certainly be a lot easier to figure out the MK Grid Plus system than it would be to design, build, site, and install a relay box.)
With MK Grid Plus, 3 switches go into a 2-gang/double-width box. You would need a 2-gang/double-width back box (and you may want to use
an actual MK Grid Plus back box for this, though a normal 2-gang back box will normally work as well --- the deeper it is, the easier it is to wire up),
a 3-module frame, a 3-module front plate, and 3 switch modules as necessary.
Note that the two lugs on the sides of the grid frame need to bear on to the front surface of your wall as this is how the assembly gets its depth-position reference. (They will be hidden by the front plate.) I usually found that I needed to make good the aperture edges with filler or epoxy putty where the frame lugs rest to get the assembly to sit just right.
Note whilst I have provided links into Gil-lec's website, I am not affiliated with them. Other suppliers also supply MK products. I just had a good result with Gil-lec.
