Our 3 way valve has been causing all sorts of issues for a while now.
It was a Danfoss HSA3. The spindle had seized and was leaking.
So I removed it and replaced the body with a Honeywell V4073A that I had spare.
The V4073A was spare because I had purchased a complete body and head to replace just the head at our previous house.
So this has cured the leak but I currently have to turn the spindle by hand!
The easy answer to this would be to buy a replacement V4073A head to go on and wire it in place of the Danfoss head.
However I have the old V4073A head and a spare brand new synchro motor.
Am I a little too optimistic that just replacing the motor will sort it?
Currently if I wire the old head up in place of the Danfoss one then nothing happens when you switch on the heating or HW. The pump doesn't kick in or anything. I kind of expected it to work on one (is it HW that is in the default position?) Could it be the circuit board that has gone? Or is there anything else? If I move the manual slider across then the pump kicks in etc.
I take it the wiring matches between the two systems?
They were nearly the same, the V4073A had the addition of an earth wire, but otherwise the other 4 wires were very similar. I replaced Orange with Orange, Blue with Blue, Grey with Grey and white striped with white.
