3 way valve, whining radiators and flushing.
11 May 2004
Bath
I have had whining radiators for several months.
I have a two pipe open-vented with a boiler in the airing cupboard.
I also have a three-way diverter, a grundfoss pump and an air seperator.
Because of the whining and the nice weather I have decided to put a cleanser into the header tank after draining the radiators.
I am not sure how the 3-way diverter works and I switched it to manual to see what happened.
I refilled the system and put it on. The radiators at the top of the house got hot quickly and the ones downstairs took a long time to warm up.
One in the hall didnt warm up at all.
I then switched the 3-way diverter to auto and heard a lot of circulation happening downstairs and the radiator in the hall warmed up quickly.
It started to whine a bit until I adjusted the thermostat knob on the radiator.
Can anyone explain what is going on?
Should the 3-way be left on auto?
yes it should be left on auto.
the whineing rad could be the pin sticking on the trv you could try re-greasing it, or if need be replace it.
