Evening all,
I've been getting into Z-Wave home automation recently - so far only using some multi-sensors and some power socket switches. I also wanted to update my living room light switch to be controllable via the system.
It's just a 1-way, 1-gang, on-off switch that controls a single light fitting... the simplest thing ever.
The place I'm buying my kit off (Vesternet, very good) have told me that I need to have a neutral at the switch to use a smart switch / relay. I absolutely understand how this works, it's all explained on this page.
http://www.vesternet.com/blog/2014/09/why-smart-switches-cant-be-used-without-neutral/
I gather if I pull the light switch off the wall and find only 2 wires in there then only a dimmer solution will work. I wanted to ask... why doesn't the UK have neutral at the switch as a standard - I'm guessing, as someone made these smart switches to sell, that some other places must do this as a matter of course?
Appreciate any insight... I thought being able to control my simple living room light would be easy... nothing ever is.
Is retro-fitting neutral at the switch even remotely possible in something that's not a new build? I mean, am I talking nonsense (probably)?
